Topic: Fuel Tank Rust Control  (Read 1013 times)
Black N Gold
Reputation +0/-0
Motorcycles: 83 Yam Vision 550
Miles Typed: 11
« on: February 27, 2008, 07:22:49 AM »
Continuing the saga of getting the 25+ year old Vision in better shape - the outside has been painted by the Previous owner, OK job - but the inside is less-than-perfect, I would call it "slight to moderate surface rust - some of it loose, with dime-quarter size spots generating it... no perforations that I can detect ywt...
So far, I've taken the fuel sender and petcock off, filled the tank with loose stuff and shaken it till my arms have fallen off , repeated, etc., for a few days...- I'll dump the beads and soap/rinse thoroughly soon... I feel better now that the old stuff is mostly going to come off, and the tank is better already - in the short run...
without spending the several hundred dollars to have the tank "professionally" done, what about a material like POR-15? Is this a step up from Kreem? Any experiences?
shah269
Reputation +45/-192
Miles Typed: 10478
« Reply #1 on: February 27, 2008, 07:35:04 AM »
You can reline it.
Not the.....safest thing to do in the world but can be done.
You clean it out with product A then you etch it with acid and then you line it with some stuff.
A friend and I did his, wasn't hard at all. But we were stoned for like a week from the chemicals!
Outrace
« Reply #2 on: February 27, 2008, 07:46:10 AM »
Try this:
http://cycletips.blogspot.com/2007/08/de-rusting-your-fuel-tank.html
Bjorn Toulouse
Destructive Tester
Reputation +0/-1
Motorcycles: CheeperHawk
GPS: N.E. oHIo
Miles Typed: 2579
« Reply #3 on: February 27, 2008, 08:03:58 AM »
I've done a number of tanks with POR-15 and had excellent results.
Many many years ago I tried Kreem on a couple of tanks without joy....lining began to flake off
in a fairly short period of time.
Both products were applied following the specific directions.
If you can scrub the rust out with the technique you're using, and there are no leaks, I would recommend NOT using any liner.
The above is based on my personal experience. YMMV
Rex
 Dood, interesting bike. Did you customize it yourself, or was it all f*cked up when you bought it?
Mr. Whippy
Reputation +52/-52
Motorcycles: 04 MTS 1000DS 00 996S
Miles Typed: 5763
« Reply #4 on: February 27, 2008, 08:15:07 AM »
I have also used the POR-15 system with uniformly excellent results.  There are a couple points to remember:  This stuff dries really hard so make sure the fuel outlets are completely clear before it does dry (ie poke something through so a film or plug doesn't obstruct the fuel flow).  Make sure you don't get any on threads or threaded inserts--again this stuff dries really hard.
thatguy
Reputation +83/-75
Motorcycles: a few
GPS: Aintree
Miles Typed: 3919
« Reply #5 on: February 27, 2008, 07:11:06 PM »
Been using this stuff four about 5 years now.I'd say we've done 50 tanks with it.One step and no BS acid etching.I would be careful about the fumes though as it has MEK in it.Did a 1972 R5 Yamaha that we thought was beyond hope.Saw the guy riding the bike a month or so ago.So it must still be working.Oh and a quart will do a couple 5 gallon tanks.
http://www.4secondsflat.com/Fuel_Tank_Sealer.html
"Speak when you are spoken to,but don't pretend you are right.............."
M.Brane
Owner of many Vs
Reputation +15/-5
Motorcycles: '98 VFR800FI '93 GTS1000A (wrecked)
GPS: 1 hr N/W of LA LA Land
Miles Typed: 2360
« Reply #6 on: February 27, 2008, 08:21:42 PM »
 I found some stuff called Evapo-Rust. Yeah, corny name, and I was skeptical it would work. I had nothing to lose though so I bought a couple bottles at Auto Zone. I poured it in the tank, sealed up the filler hole, and spent a couple hours shaking it around. Let it sit for a while on each side between shaking sessions.
 It worked. No more rust. Even got the pits.
 Non-toxic, boidegradable, and doesn't eat paint or bare metal.
Jes_VFR
Reputation +1/-0
Motorcycles: 2001 Honda VFR, 2002 Honda RVT1000 SP2
GPS: NJ, USA
Miles Typed: 1747
« Reply #7 on: February 27, 2008, 08:35:49 PM »
+1 on the redkote. I have used to it make sure that fabricated gas tanks (on cars) are sealed after all the welding is completed.
JohnS
2001 VFR
2002 RC51  forging my body in the fires of my will
PhilBiker
HOV Commutosaurus
Reputation +11/-1
Motorcycles: '95 Kawasaki GPz-1100
Miles Typed: 1227
« Reply #8 on: February 28, 2008, 05:08:02 AM »
Is that a 25 year old Yamaha Vision?  I vaguely remember there was some kind of catastrophic engineering defect with that bike.....  Good luck. Smile  Sorry I can't remember anything more.  Neat bike BTW.
PhilBiker
squeezer
Squirrelly Geezer
Reputation +99/-29
Motorcycles: 03 FJR 1300, 98 Ninja 250
GPS: Middle o' Nothing, PA
Miles Typed: 4416
« Reply #9 on: February 28, 2008, 06:21:13 AM »
Yes.  It was brought to market ahead of its time.   Wink
I loved my Vision.  Didn't own it very long, though, so if there was such a defect I never found it.
Always be yourself, unless you suck.  -- Joss Whedon
Top of the Bell Curve Rally Team t-shirts and stickers are here! (thongs too)   AND  Awesome FJR shirts and swag here!
AMA, IBA, AARP, DENNY'S BURGER RUN ('07, '09), RIDE TO THE RIDES ('10, '11)
thatguy
Reputation +83/-75
Motorcycles: a few
GPS: Aintree
Miles Typed: 3919
« Reply #10 on: February 28, 2008, 06:27:24 PM »
Nah you're thinking about the TX750 which was a total disaster for Yamaha.It was a counterbalanced twin.At higher RPMs the counter balancers would aerate the oil and starve the crankshaft with catastrophic results.Nice bike with a huge screw-up.There are a few examples of the '73-74 run out there.
PhilBiker
HOV Commutosaurus
Reputation +11/-1
Miles Typed: 1227
« Reply #11 on: February 29, 2008, 05:03:55 AM »
Actually I was specifically thinking of the Vision, but that TX750 sounds like a real problem! Smile
A little googling found the problem This former owner talks about a poorly engineered O-ring seal which chronically wrecked starter motors.  That rings a bell - he also discusses a cheap fix for the problem, which may help the OP!  I think there were other problems with the Vision as well.
PhilBiker
ZZR Rob
Reputation +11/-2
Motorcycles: 02 Concours
GPS: Sharpsburg, MD
Miles Typed: 770
« Reply #12 on: February 29, 2008, 02:12:41 PM »
Kreem worked well for me on a 72 DT250 tank, just followed the directions to a tee.
Good Luck and have fun.
